communication between two sb rio
how can start of for  implemeting redundancy using two sbRIO boards....
(3,480 Views)
You should consider using the network connectors of your sbRIO device to have them communicate with each other…
(3,437 Views)
there is one ethernet port  and other is RS232
which is prefered and and more efficient?
(3,412 Views)
Hi irfan,
"network" usually refers to the Ethernet port.
"Efficiency" depends on definitions! 😄
But using the 100Mbit (?) LAN will probably faster/more capable than those 56.7kbit RS232…
(3,406 Views)
