communication of PLC with PC via TCP/IP
hi all
i need to communicate the PLC(CP315-2DP) in LabVIEW via TCP/IP..Is there any idea?....
Thanks in advance....
(2,972 Views)
Look up TCP/IP in the Example Finder (Help -> Find Examples). Also, try to make your questions as specific as possible explaining the issue at hand.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,966 Views)
I communicate with PLC through the module of CP343-1 Lean via TCP/IP on LabVIEW.I am in need of fetching some datas.So my doubt is in the command for read write operation.
(2,952 Views)
