communication with Yokogawa gx recorder
Hi
am using yokogawa gx2030 recoder...it has both ethernet and serial port..
can anyone tell me that, is it possible to communicate over ethernet and serial port at same time through labview..
ie. i want to fetch datas from recorder through ethernet and serial port parallely
(2,586 Views)
In LabVIEW it is no problem to use more interface to one, in this case, recorder.
For the recorder the Serial interface (C2/C3) is an option. Maybe the recorder can communicate on both interfaces.
With T&M instruments from Yokogawa you have to choose an interface on most (if not all) instruments. So there it is only possible to communicate with one interface.
Just build two simple VI's which will communicate with the recorder, run them both at the same time and see what happens.
Kees
(2,568 Views)
