como enviar mas de 64 bits via TCP IP
Hola , estoy tratando de enviar datos de mas de 64 bits via TCP IP , quisiera que me ayudaran a poder resolver este problema ; cualquier sugerencia es bien recibida gracias
(2,812 Views)
English Translation:
I'm trying to send 64 bit data via TCP IP.
I would like to solve this problem, any suggestion is welcomed.
(2,802 Views)
you can use the "flatten to string" function to send whatever data you need.
Mike
(2,800 Views)
Suggestion: Take a look at the TCP/IP examples that ship with LabVIEW. There's a Simple Data Client and Simple Data Server that should get you started.
(2,783 Views)
