compact rio Real time signal processing Jitter
i'm conducing active noise control with 5 microphone and 5 speaker.
control algorithm wroted in RT not FPGA because the algorithm complicate
then i didn't make window monitor VI just watch outcome of signal processing in RT
i'am running RT with sampling rate 1600Hz dt = 0.000625 but there is some Jitter from dt =  0.00061x to 0.00067x
my question is
1. the Jitter that i experience is normal?
2. Explicit Conversion in RT have influence on Jitter?
3. Is FPGA RT  better than DSP chip in signal processing? i think if i rise sampling rate in RT, the jitter is large. same thing happen in DSP microcontroller?
Message 1 of 1
(846 Views)
