compare 2 listboxes with different sizes
I need to compare 2 listboxes A and B which have different sizes.
The rules of comparison are: if an element in A is found in B then i should keep this element in A.
                                                    if an element in A is not found in B then i should erase the element from A.
The result of the comparison is a listbox that should replace the listbox A.
The problem is that the listboxes sizes are different. Could u help me ?
Samer,
(3,569 Views)
Certainly not the most elegant way...but it works !
I substituted listbox with array - but the idea is the same. Does it fit your need ?
(3,552 Views)
Hi Samer,
use a for loop. Connect the elements from listbox A with autoindexing to the loop and the elements from B without autoindexing. Search for the A elements in B, use the "search 1d array.vi" for it.
Mike
(3,550 Views)
I'm sure I could do away with the build array function :-S
Hah, you both beat me to it
Message Edited by yenknip on 07-30-2008 11:38 AM
_____________________________
- Cheers, Ed
(3,541 Views)
hi
اريد الحصول على نفس المثال
(3,182 Views)
