compare array and output common elements
WOOPS!!!  I apologize...I just quickly scanned the error message I got when I tried to open up the vi.  If I read it properly...it said, "labView load error code 9: VI version (8.5) is newer than LabView version (8.2)."
My bad.
Back to the original question, the blocks that are colored light green.  One of the blocks have "[dup]" in the lower right corner.  I don't see those block in the normal 'array' options.
hiNi.
Message 11 of 16
(2,945 Views)
Ahh, you are referring to the green functions in JCarmody's post.
Those are 'custom' VI's that he found in OpenG's forums.
User's can create VI's and then share them freely.
JCarmody, would you mind stepping in and telling hiNI where he could find those VI's?
Cory K
Message 12 of 16
(2,940 Views)
Here are the OpenG array functions
The two he used were:
Remove Duplicates from 1D Array
Delete Elements From Array
Cory K
Message 13 of 16
(2,933 Views)
hiNI,
This link will tell you how to install the OpenG functions.  It's a small investment in time, and the returns are fantastic. Smiley Wink
Jim
Message 14 of 16
(2,929 Views)
THANK YOU!
Message 15 of 16
(2,927 Views)
The important thing about this solution is that:
A) Jim should have used the Code Capture Tool :smileywink:
B) Both original Arrays should not have duplicate items
Ton
My LabVIEW Ideas
Message 16 of 16
(2,884 Views)
