compare array , search for for 2 depending values and output matching elements
my  problem is to extract elements from a 2d array imported from excel. For example i need the elements from a row , where the value of column 1 and 2 match 2 values i want to set (differnt values for column1 and 2 / later theese are measured).I tried this by using the index array and search array function and wanted to compare the index of the  columns where the values appeared with a simple case structure and than extract the desired elements with another index array function ,but this doesn't work.
How can manage it ,that the search1d array function doesn't stop at the first matching element , and how could i compare the resulting index with another one from the 2nd column ( making a comparison with  the equal function send through a case structure didn't work for me).
Any ideas?
Message 1 of 8
(3,970 Views)
I'm not sure I entirely understand what you are trying to do.
If I understand correctly:
This will iterate through each row of '2D array'.
It will check the value of 'column 1' vs 'value 1' that you specify.
It will do the same for 'column 2' and 'value 2'.
If 1 is a match AND 2 is a match, it will say "you have a match"
If not, it will say "no match"
Message Edited by Cory K on 05-07-2009 11:44 AM
Cory K
Message 2 of 8
(3,956 Views)
Using = to compare non-integers is not a good idea.  Due to the way numbers are represented in the computer, equality matches do not work as you might hope they would.  It is better to use the In Range and Coerce or similar logic with the upper and lower limits changed from the nominal value by the Machine Epsilon (I think that is what it is called) or more.  Machine Epsilon is the smallest difference between two numbers which can be represented by the corresponding datatype (DBL for example) on that computer.
Lynn
Message 3 of 8
(3,950 Views)
Lynn
Ditto Lynn's comments.
Your question alomst reads like you are trying to map values to scales (not sure). If so check out the "Threshold 1D Array" and its counter-part the "Interpolate 1D Array". You pass a measured value to the first, it finds an index that matches the value you are trying to map and then use that as the input to the Interpolate and it will give you the value that matches up from the second array and will perform a linear interpoaltion if in-between.
Have fun!
Ben
Message 4 of 8
(3,940 Views)
Thanks to all of you, but I already could fix my problem. Sorry that I haven´t replied earlier I was a quite busy.
Message 5 of 8
(3,910 Views)
@Student111  작성:
hy could you please upload that problem solution.
Message 6 of 8
(2,977 Views)
That person hasn't been on the forum in nearly a decade.  I doubt they'll see your message to reply.
Message 7 of 8
(2,971 Views)
@RavensFan  작성:
Thanks RavensFan,
Message 8 of 8
(2,969 Views)
