compare fuzzy inference in labview and matlab
Dear all
 I made a fuzzy block in Labview and now I want to make the same system in MATLAB although I tried to set everything the same but the output are not the same in Labview and MATLAB.
I use Labview  8.2.1 and MATLAB 7.7 which is equiped with fuzzy toolbox 2.2.8.
The fuzzy system parameters in MATLAB are:
       andMethod: 'min'
        orMethod: 'max'
    defuzzMethod: 'centroid'
       impMethod: 'min'
       aggMethod: 'max'
and in Labview:
 Defuzzification method: center of gravity (which I think should be the same as 'centroid')
Inference method: max-min
All the rules and fuzzy terms are the same and I checked the fired rules which are the same with same weight for each entry.
Do yoou have any idea why these two are different?
Best regards
Afshin
(3,151 Views)
I don't have much for specifics, but the two programs implement the fuzzy logic algorithms differently.  Because of this, you will not get the same output from both programs.
Alex Person
NI-RIO Product Support Engineer
(3,134 Views)
