compare two waveforms
In my application, I will be comapring a waveform acquired from a USB based NI data card and comparing it with a master already stored in PC. To simulate this condition, I wrote a simple program. I used the express vi for comparing 2 signals. However I want to change the tolerance of acceptance to with within the 5% or 10% of the master.
I tried using the settings that the express vi provides, but doesnt seem to work for me accurately.
Is there any other way to do this?
I am attaching my vi's with this.
Thanks!
Message 1 of 8
(5,718 Views)
I would change the code to be something more like this.
Message 2 of 8
(5,693 Views)
I tried doing the changes you suggested. But I am not getting the desired output.
Am I doing something wrong?
I am attaching my vi.
Message 3 of 8
(5,659 Views)
Message 4 of 8
(5,645 Views)
Hello!
Thank you for your response, I have Labview 2009 version. Can you send for the same?
Thanks in advance
Message 5 of 8
(5,634 Views)
saved to the version of 2009, but I'am not sure if it works like the original one.
Message 6 of 8
(5,593 Views)
why my attachment is not shown properly!
Message 7 of 8
(5,583 Views)
Hi!
Thank you for your response.
It still gives me an error when I try to open. Anyway, I have made another vi which works fine but I have yet to check it on hardware. Will post it as soon as I check it.
Thank you all for your responses. 🙂
Message 8 of 8
(5,555 Views)
