comparing 2d array of string with constant
I have a VI which is using activex to read from a spreadsheet. I have am reading a 1 column by 13 row array from the spreadsheet, the data of which is either TRUE or FALSE for any of the elements.
I then want to compare each of the elements to see if they are = to a constant of TRUE to set 1 or more of 13 boolean indicators on my front panel
Can this be done and if so how?
Thanks in advance
(3,852 Views)
Thanks in advance
Definitely.
You need a 1D boolean array.
Please post a VI of your attempt.
(3,850 Views)
Here is a hint... Assuming you are storing the spreadsheet you read in a string array
=== Engineer Ambiguously ===
(3,842 Views)
Oh by the way,  1x13 is a 1d array. Smiley Wink
(3,803 Views)
Not really, since we have two dimensions (1 & 13). In order to make the first column of a 2D array a 1D array, we need to use index array with a zero wired to the lower index.
(3,798 Views)
Oh, yeah I guess you are right. If the OP is using "Read From Spreadsheet File" vi then it does output a 2d array except for the "first row" output.
(3,796 Views)
Yes, he could set "transpose?" to TRUE and use the first row output, which would give te first column instead. 😉
(3,788 Views)
