comparing digital input and output from two different DAQs
I think you should quit all those loops and use a state machine mechanisme.
State 1 : Initialize controls
State 2 : Initialize DAQmx tasks
State 3 : Do some LCD stuff maybe
State 4 : Write an output value to the led's
State 5 : Read digital inputs
State 6 : Compare inputs with led's if not equal goto state 5, if equal goto state 7
State 7 : Update score and display
State 8 : Check stop button if pressed goto state 9, if not pressed goto state 4
State 9 : ...
This way your digital inputs will read continously while now it's only read after each game-level-time.
This way you also be able to determine the reaction time.
So, if I were you I would review the architecture of the code Smiley Surprised
Message 11 of 58
(1,178 Views)
once again, thanks Alain. I'm not too familliar with the state machine though as I only started self-learning LabView a few months ago. Perhaps if you could start me off with the state machine thing for me to have a better understanding?
Message 12 of 58
(1,170 Views)
You can find a brief introduction to state machines here.  You can find a template to start with in LabVIEW. Select File»New... then navigate to VI»From Template»Frameworks»Design Patterns»Standard State Machine.  Search these forums or the web for many other examples.  The only caveat I would give you is to avoid state machines which switch on strings - always use a typedef enum.  This will make your future development much easier.
Message 13 of 58
(1,163 Views)
Absolutely!!! typedef is the only right way to go:)
But how to make a typedef?
Don't bother use this one as a start, just replace all the state names with your own state names.
Message 14 of 58
(1,158 Views)
And now the whole framework for a state machine. Please note that the code inside the states doesn't mean anything now since I removed most of the controls of that program.
Up to you now to:
  • Copy all of your controls into this framework
  • Define some well defined states
  • Modify the code and type defs according to those states
  • Maybe you can use the "Settings" stuff to store the last top scores with player name and DT stamp 😉
You can download the Open G tools as discribed here
Share all of your new code so that we all can play that game Smiley Very Happy
Good luck !
Message 15 of 58
(1,150 Views)
Oeps, forgot the code Smiley Surprised
Message 16 of 58
(1,148 Views)
thanks a lot! SHall be posting it up once I finish it 🙂
Message 17 of 58
(1,138 Views)
I've completed my code and can someone tell me if its working in sequence as stated below? I think i made a mess of things  :S thanks..
1) Enter user name
2) Select level
3)Remaining time is displayed on the 7-segment
3) LEDs light up at random for 1 minute
4) Corresponding push button is pressed
5)Correct score? +1 mark
6) Remaining 5 secs, plays a beep.
7)End of game, another beep.
😎 Score is displayed on the LCD
9)  Score displayed on monitor
10) Beep if new high score is set
Message 18 of 58
(1,129 Views)
One thing is for sure, you're using a state machine!
But is it well implemented? Not 100% sure about that Smiley Sad
What I miss is an Idle state like in the statemacine I posted.
In the Idle state you should put the event structure and use it as an event structure.
Now you use an event structure as a level time out for the user.
You should implement the level time out as follow
Write a code to the led's
Add the level time out to the actual time (ticks since midnight)
In the Time out state of the event structure in the Idle state, compare that time with the actual time.
Is it overdue, go to the state "Write to LED's"
You're Stop button is in the "Start Timer" state 😞   Really confusing 😞
The user inputs name & Level selector should be in a state, same for the message at the end
Both cases of the case structure in "Compare read and write" go to "Write to LEDs" state ?!?
Skip the Wait function with 125ms because now you read you're inputs at maximum 8Hz
Clean up all those blue wires at the top of your VI. I didn't check what they are for but I'm sure there's a better way ... ...
I hope I didn't discourage you too much
Message 19 of 58
(1,124 Views)
Ok.. but could you elaborate more? I'm getting confused.. And what exactly is the idle state for? And for the level time out, am i supposed to write everything in 1 event structure? or seperate?
Message 20 of 58
(1,117 Views)
