comparing values of the array with the previous value
Hallo guys, I need help with a project that evaluates measured data from sensor.
I need to compare each element of the array with the previous one, if the current value is larger then the pervious it will continue comparing until the current value is less than the previous one and it will print out the max Value.
in other words I'm trying to find the max Value of each peek in my measurements.
thank you guys in advance
(1,794 Views)
This may be useful
Santhosh
Soliton Technologies
(1,787 Views)
Thank you sir,
 I did it with this function
(1,771 Views)
Hi Majd,
I don't think you should use an IMAQ (IMage AcQuisition) function to analyse a DAQ signal…
Why don't you use the "default" PeakDetector?
(1,753 Views)
hallo,
Ah Ok, I didnt know the difference, but now I used the default Peak detector and it works.
Thank you fro your help
(1,688 Views)
