Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
comparison between entered value and stored value
P.Rayne
Member
10-03-2003
01:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
An user enters his or her code, the code needs to match the code which corresponds to her code in the file, else the value is set to zero and asks to be re-entered, if correct to proceed.
hell.vi 63 KB
0
Kudos
Message
1
of 2
(2,519 Views)
Reply
Re: comparison between entered value and stored value
Mads
Active Participant
10-03-2003
02:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
And what is the problem?
Using the constant seems to be working as you describe, is it when you read a file there is a problem? If so could you supply one such file?
Mads Toppe
Check out our Modbus Test Master - developed in LabVIEW
0
Kudos
Message
2
of 2
(2,519 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
