comparison in hexadecimal - help needed
hello,
i am basically using VISA read and write. There is infor sent to my computer using RS232. Only when i recieve that infor
I need to send out some data.  so I open up visa and start "VISA Read". the information coming in is:
"01,\n\r" or in hexadecimal: 30 31 2C 0D 0A
I then use a comparison to see if the above matches with a string that is the same as above..
BUT THE PROBLEM IS IT ALWAYS SHOWS FALSE THAT THE STRING DOES NOT MATCH???
does anyone know why??
thanks
any similar VI's
(2,597 Views)
Flip the last two characters:
"01,\n\r" is 30 31 2C 0A 0D (not 30 31 2C 0D 0A!) 🙂
(2,595 Views)
