compatibility to Biopac equipment
How is LabView compatible to Biopac equipment (phisiology data acquisition)? I have seen it in brochures and articles from IEEE Engineering in Medicine and Biology Magazine.
I would like to have more info before making a purchase decision.
Thank you
(2,683 Views)
Hello �
You can use LabVIEW to process data acquired with 3rd party hardware. The way you do it depends on what type of interface your hardware uses. For example, if you have:
a. A PCI Plug-in Board
b. A USB or IEEE 1394 (FireWire) devices
c. A Serial instrument
d. A Parallel Port device
e. An Ethernet device
Hope this helps!
S Vences
(2,683 Views)
