compile exe choke
I am trying to compiile an exe.  After I hit hit, I see the process bar, but the progress bar doesn't change.  It is as though the build process is choked.  What can I do?
Kudos and Accepted as Solution are welcome!
(3,295 Views)
Could you create a new project and build a very basic application (as simple as an addition or a VI from the Example Finder)?  Please let us know if you are able to build this Test project.
The next resources are recommended when you are building applications; please take a look to the check list.
https://www.ni.com/docs/en-US/bundle/labview/page/building-and-distributing-applications.html
http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/build_checklist/
MCOTO
(3,247 Views)
Are you sure it's not building?  Sometimes it can look like nothing is happening if you have a very large build or you are building something on a network drive.  I remember thinking one of my builds wasn't working, but after a few aborted tries, I just let it go and walked away.  When I came back about 5 minutes later, it was done.
Bill
CLD
(Mid-Level minion.)
(3,243 Views)
Installers take foreveer to build but they do finish. (finally)
(3,237 Views)
Accepted by topic author jyang72211
I found the problem.  The pre-build vi was trapped in an infiinite loop.  After I fixed that, the problem was resolved.
(3,203 Views)
