compiler error cpd tc=0X30
My sub VI showed one compiler error
I attached the picture and my vi
Thank you so much for your help
(3,323 Views)
Hi dragon-long,
Try copy-pasting the code into another VI and saving it and then use that as the subVI. Sometimes that fixes issues like this.
Kaitlin N.
(3,307 Views)
I tried . But still does not work
(3,291 Views)
I tried to open the VI and no compiler errors on my computer, though, there was missing VI's
The problem seem to be located in Header-PR2000-MFC (SubVI).vi, try to comment out code inside that VI and use "divide and conquer" approach for deducing whre the culprit is located.
Br,
/Roger
(3,275 Views)
I will change a PC to look at it
(3,262 Views)
Hi dragon-long,
Can you also post your code in a zip file with the missing control and subVI included. That will help us be able to properly run your code.
Kaitlin N.
(3,251 Views)
I had the same problem and easily found a piece of code we had in common.
Removing the unnecessary compound arithmetic solves the problem.
Kudos welcome. 😉
(3,176 Views)
