complex value of the sine wave
Hi everyone,
I am serching somethig for show complex valeur. I've made in to way but they are not precise. Indicater value are varie in the large field. I need goog values for impedance calculation of circuit.
If you can help me? - Please.
19617i956B0417B319B09C
(2,315 Views)
I'm sorry, but your question is not very clear. What complex value are you trying to show? What's not precise? Precise compared to what? Some calculate value, or the value determined by some other application? You said the indicator value "are varie in the large field". I have no idea what this means.
Can you rephrase your question, and perhaps provide some sample data? I.e., an actual waveform with what you want to have measured and what you believe should be the correct value.
(2,300 Views)
