computer does not boot when pxi 1033 is connected
hiiiiii...........i am using NI pxi-1033 for my application & this pxi is connected to my system through PCIe-8361. i am using it from last 10 months, now suddenly my computer does not boot up. i start pxi first then start the computer but computer screen shows no signal. there is no blue screen error.
can you give me any point to troubleshoot the problem.
(2,679 Views)
This probably doesn't help, since your setup used to work, but I have had to run the MXI Compatibility Tool on more than one PC.
http://joule.ni.com/nidu/cds/view/p/id/3119/lang/en
One PC would only boot one time in ten, before running the tool.
(2,673 Views)
before one week i change PCIe-8361 & cable because computer does not start & create a sound of beep- beep. after changing card it start working then now it again but this time there is no sound of beep.
Can you guess is it a card problem or MXI?
(2,657 Views)
