concanate 2d waveform array
Hi everyone.I want to concanate 2d waveform array?How to concanate these 2d waveform arrays.(Waveform y array size =60000)
(4,080 Views)
You can do by the following way but holding 60000 data is not advisable as it may slow down the performance of your system.
You may get even better solution this. Good luck
(4,074 Views)
Not three waveform arrays ?  for N piece waveform
Wave1
Wave2
Wave3
WaveN
(4,067 Views)
Himmet,
Here is how I went about dynamically appending waveforms. I took what P Anand wrote and modified it to stop on a condition. You should be able to take this and modify it to stop when you want. If you already have your data from outside the loop then switch the while loop to a for loop and input the number of segments into the N terminal.
Kyle Hartley
Senior Embedded Software Engineer
(4,033 Views)
Wave1
Wave2
Wave3
WaveN
Please tell what you want in the end.
P. Anand's solution is valid but apperently not what you desire.
Show what you want and we may be able to assist.
Until I know what you really want I will not try guessing.
Ben
(4,025 Views)
