condition to complete excution of program?
i have aprogram and want to divide it into two parts,
part one excute nornally when press ctrl+r
part two doesnot excute until i press certain button
so i want function to stop excute after part one finish and out message to press button to complete excute part two
what function should i use??
thanks in advance
(2,215 Views)
The function I would use is probably a state machine.
LabVIEW 2012
(2,210 Views)
I would also recommend looking at this example, it should help.  Also, you can also start with a state machine template from the getting started screen.  Go to VI from template -> From Template -> Frameworks -> Design Patterns -> Standard State Machine.
David B
(2,187 Views)
