conditional meter - basic level
Dear Sirs,
I would like to know (if possible) how can I make conditional meter (see my vi attached) , that change the range (min - max) as the input change
in my example, when the simulate signal is below 3 the meter shoud range from 0 to 2 , when it is from 3 to 7 tha meter should range from 4 to 6 and finally over 7 tha rnage should be fro 8 to 10
I know that is shoudl be simple bu .. all my efforts with the case structure fails
every help will be really appreciated
Thank you very much
Matteo
(3,190 Views)
Is this what you are looking for?
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,186 Views)
Dera Betcktho,
thank you very much,
it is exactly what I have in my mind
sorry for the delay but I went out for business for few days
(3,163 Views)
