config Daq express via control
Hi there,
Is it possible to configure channels in daq express using a control input in the front panel. i ask this cause im doing an exe and in the possibility that circuit module inputs are changed i cant acess the code for exemple.
asnaev
(2,499 Views)
No.  The DAQ Assistant is intended for quick, easy setup of some basic DAQ functions.  It isn't intended for full flexibility.
You will need to use the lower level DAQmx functions so that you can have direct control over what channels you build into a task.
(2,491 Views)
The whole point of "Express" is that it takes away all those advanced options so it's less confusing for noobs.  If you want to control your DAQ configuration, just dump the DAQ Assistant and write real DAQmx code.  Start with the examples and you'll find it's quite easy.
You can also start with the DAQ Assistant and do your basic configuration.  Then, right-click it and select 'generate DAQmx code'.  You'll find all the config stuff in a subVI with constants you can convert to controls...  (It's also a good way to learn DAQmx coding)
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,487 Views)
ok.
I was expecting that answer :). i need speed so i will not lose the express.
Thx anyway.
asnaev
(2,471 Views)
