configure CYDAS ULV board.
I am trying to communicate to the UCERB 24 board.  I installed InstaCal, and ULforLV711a - but LabVIEW gives me the error: Before continuing, run InstaCal to complete installation and configuration of your device. Then restart LabView to load the configuration information.
How do I configure my device?
-Ayana
(2,677 Views)
I'm not really familiar with Cyber Research's Relay Module or InstaCal.  Is this an installation issue with their driver and if so, have you contacted Cyber Research?  And I couldn't find anything about ULforLV711a.  Can you provide additional information?
Are you seeing this message when you launch LabVIEW or when you try to use VIs fromt the driver?
David_B
(2,647 Views)
