configure installer
Hi All!
My project includes a dll library, and it works fine. But when I build an installer and application exe the dll doesn't work, even on the same machine. What is wrong?
Other question- my projecy uses labview.exe's exported functions, how to include the file in my installer?
thanks
Przemek
Message 1 of 8
(4,658 Views)
Hi Przemmo,
I think you may have missed out to include your dll file in to the dynamic VIs portion while you are creating the exe and then installer. Check it once again.
MRK (CLAD)
Message 2 of 8
(4,647 Views)
You mean in "Always Included" vis?
Message 3 of 8
(4,626 Views)
Yes
Message 4 of 8
(4,610 Views)
I have included it. Any other idea?
Message 5 of 8
(4,598 Views)
Still is it not working?
What is the status now?
Message 6 of 8
(4,596 Views)
The DLL should be in the same folder as your application is after build.
Another thing could be that this DLL needs other DLLs which you didn't include in the build.
If you are using functions directly build into LabVIEW.exe you have to include LabVIEW.exe as any other DLL. Don't be surprised when LabVIEW then wants an activation.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 7 of 8
(4,587 Views)
I included all the files in my project (please find the attachements).
If I run the vi's from labView (as *.vi) dll works good. When I run it as an application there is no error but the tab returned by my dll is empty (contains all zero's).
Message 8 of 8
(4,562 Views)
