configure shared variable programmaticaly
I use Single Process Sared Variables in an RT application, and I would like to configure some parameters programmatically, like the RT FIFO parameters (FIFO type, number of arrays, number of elements in array).
If someone can explain me how to configure this parameters programmatically in my code, or provide me an example, it will be very appreciate.
Thanks in advance.
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
▶ Check out my LabVIEW presentations and videos!
(3,397 Views)
whether or not your using DSC see the thread How do I get/set a shared variable programmatically? I found the DSC module has a good starting example to work with...
(3,384 Views)
Accepted by topic author mbaudot
There is a document in the Knowledgebase which solve my problem.
http://digital.ni.com/public.nsf/allkb/4757137A667431FD862572440008614E
This document permit to obtain a Shared Variable reference. Then, I've just to use the property node to configure my parameters.
(3,363 Views)
