configuring array of byte in dll call
Dear all,
I need to send the data 2010010100H to the dll at the question mark(U8) i mentioned in the attachment. Actually the data has to be transferred at a time not in bits and pieces. How to do this? I just put an array constant. Is it correct? Kindly give suggestions asap.
Mathan
(2,325 Views)
Hi mathan,
the dll call in your pic only accepts single bytes (U8) - so no way to wire an array!
why do you create so many new threads, when the topic doesn't change?
(2,311 Views)
