configuring cRIO to see 9214 modules
I have installed a new cRIO9081 system and can see it as a remote system.  However, when I add a Ni-9214 module, it does not see the module, even after I refresh and restart the cRIO. On the old system (cDAQ-9188, this worked.)  Is the cRIO not a plug and play type of system?
(3,001 Views)
Where are you trying to see it?  The cDAQ comment makes me think you're looking in MAX.  You won't see any modules there for a cRIO.
Create a project and add the FPGA Target.  You'll find modules under that tree.
(2,979 Views)
create a project in Labview?  I'm sorry to ask questions like this but I've never used DAQ or cRIO systems like this before.
(2,958 Views)
Have you taken a look at our Getting Started with CompactRIO and LabVIEW guide? It walks you through setting up the cRIO and the modules in a LabVIEW project. Take a look here: http://www.ni.com/pdf/manuals/372596a.pdf
Daniel C.
(2,948 Views)
