configuring run time language for applications
I have a problem in Scan From String node. The node takes the System language for parsing and converting to timestamp.
For Example, If the system Language is Dutch(Netherlands) we have to give "Do" instead of  "Thu" for Thursday.
Is there any way to force LabView to use only English Language irrespective of the System Language.
I referred this link Language preference and found AppLanguage key to give the language. I added this Key to LabView.ini file with value "English". It was not working. I also tried other values like "english","en". These were also not working. Please also specify how we must give value for the above-mentioned key.
Please go through the VI to get a clear picture of the problem.
Viknesh
(2,905 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3QKCAY&l=en-US
[Edit: Note: Strings in menus (such as File, Edit, Project, Help, and so on) and pop-up menus depend upon the version of the LabVIEW Run-Time Engine you are using with the executable. If you use the English Run-Time Engine, the menus always appear in English, regardless of the language of your operating system. Localized versions of the Run-Time Engine are available in French, German and Japanese, from the National Instruments Support site.].
(2,848 Views)
