confirming filename
When I use the Write to spreadsheet VI the program allways asks to confirm
the filename. The right filename appears in the dialoge box, but I must hit
enter before it will write it. How can I automate this??
(2,974 Views)
But a boolean constant of True donw and wire to the "Append to
File?" terminal.
the default is false and it wnats to create a new file which already exists.
Kevin Kent
(2,974 Views)
If a file exists that your writing to then you need to wire the append to
file
control True. This will append data to what you've already written.
Pat
"Do_It_To_Me" wrote:
>When I use the Write to spreadsheet VI the program allways asks to confirm>the
filename. The right filename appears in the dialoge box, but I must hit>enter
before it will write it. How can I automate this??>>>
(2,974 Views)
