conflict of path
how to change the path of a file when you recieve warning that there is a conflict of path ?
(3,210 Views)
What version of LV are you using?
Are you running the VIs within a project?
If yes, you can use the project window to resolve those conflicts.
It sounds like the error/warning occurs because of crosslinking.
Norbert
Norbert
Expert: Geometry
(3,199 Views)
Hi Norbert,
I am using labVIEW 2012 and in a project structure. I want to change the path from where my VIs are loading. How do I do that. For eg: if they are loading from C/users/Labview and I want to change it to C/documents/ signal. what is the procedure?
(3,197 Views)
If you refer to LV static dependencies, swap to "files" tab and right click the module you want to move. In the context menu, select "Move On Disk".
If you refer to dynamic dependencies, you have to adopt the code. Still, i suggest you to move the source by the step mentioned above.
Norbert
Norbert
Expert: Geometry
(3,194 Views)
