conflicts when changing project
Me again!  Another conflict question.
 I am working with two projects, which (for sake of argument) we can call  A and B.
I work on A for a time. I run my Teststand sequence and it is fine. I then push it to CVS.
Next I switch to working on Project B ( which uses common VIs stored in its own folders).
However, when I open Project B in LV it is full of Conflicts. These I fix, run the sequence and then save it.
Now I change back to Proj A.  However, it is full of Conflict errors!!!!!!
What is happening!?
 In an effort to fix this, I fully recreated both projects, and explicitly defined which VIs to use in each case and where to get them from. However I still get conflicts when switching.
  Any ideas?
(4,750 Views)
You mentioned your TestStand sequence - are you unloading the LabVIEW modules after running it from TestStand (from file->unload modules)? Any LabVIEW code loaded into TestStand will stay in memory until it is unloaded manually (or you exit TestStand).
(blog)
(4,748 Views)
oops ignore this post
Bill
CLD
(Mid-Level minion.)
(4,743 Views)
I've even tried rebooting the PC, to be doubly sure of flushing out any VIs in memory.  Also,  I rename the project which I am not working on.
 Out of interest, is it possible to set Teststand to unload automatically, when it finishes running?
(4,735 Views)
I believe you can programmatically unload the modules as part of your sequence (e.g. at the end), or add it into one of the built-in sequence models.
If it's still happening after you reboot your PC, then you have a genuine conflict you need to resolve - some VIs are calling VIs from the other project or vice-versa. All of your project specific files should be located in the same folder (or a sub-folder) of your .lvproj file, and anything else (e.g. shared VIs) should go into user.lib/vi.lib etc.
(blog)
(4,720 Views)
Now I have a question-  That is not to say the "Load-Unload" files from the *.seq options won't help (They just might)
Does your sequence call vis through the associated lvproj context?  As I understand things, The vi with the right name in the search path options will load first in TS unless, you give it a "Fully Qualified Name" by calling through the *.lvproj at which time the *.lvproj is queried for an exact path.  (Just open a *.lvproj in notepad- you'll understand when you see the vi paths listed in human readable text)
You also seem to have multiple projects (*.lvproj files) linked to common reuse vis.  Where are those common files?  <LabVIEW>\User.lib\MyStuff\ CommonVIsXYZ.lvlib would be a nice parking spot for thoseSmiley Wink  A few more details and we will get you on the path to success! (If my 8-Ball hasn't already given you the right information)
(4,706 Views)
