connect 1d array of strings to an input string terminal
The %d just specifies that a number that should be formated as a decimal string goes into that string location.  The value you wire into it is what goes into the string.  If you took a good 5 minutes to figure out what was happening, you would realize that you could just remove one of the increments (since i =0 on the first loop iteration).
Message 31 of 40
(1,898 Views)
@reggie2016 wrote:
one question using the percent sign for the channel name is there any way we can get it to start for 0 instead of 1.
remove the "+1" wired to the desired index terminal and simply wire across instead.
Message 32 of 40
(1,891 Views)
the program is working but it is only showing the last 3 signals from each DAQ module.
Message 33 of 40
(1,870 Views)
That sure is a nice picture, I wonder what the code behind it is.
Message 34 of 40
(1,865 Views)
Message 35 of 40
(1,860 Views)
Instead of reshaping, you could just autoindex on both loop boundaries to get the 2D array.(Try this first. currently, you only get the last value from the inner loop).
Message 36 of 40
(1,850 Views)
Did you mean to read from 27 different channels, but throw away the first 26 ones that were read?  That inner for loop runs but the output is set to last value instead of indexing.
Message 37 of 40
(1,846 Views)
what do you mean by auto index
Message 38 of 40
(1,843 Views)
Accepted by topic author reggie2016
Right-click the inner brown tunnel and set it to indexing. Delete the reshape array function.
Message 39 of 40
(1,840 Views)
ahh ok thank you. thought it was in the array pallete.
Message 40 of 40
(1,833 Views)
