connect LV dsc to rslinx
I'm working on a program  Using RSLinx OPC Server" . I successfully did the "Confguring an Allen Bradley PLC in RSLinx" and "Conecting Server Explorer to RSLinx",and installed the DSC model in Labview, however, when I try to Connecting the LabVIEW DSC Module to RSLinx, i find that when I follow the steps as follows
  1. Start LabVIEW 8.2 and open a new project.
  2. Make a new library called IOServer.lvlib (doesn't really matter what the name is)
  3. Right Mouse Button (RMB) on the library and create a New:I/O Server
I can not find I/O server option after I RMB
I really want to figure out why did it happen? and is there somethig wrong with my LV DSC model?
(2,939 Views)
The only other thing I can think of is to try rebooting your computer... Some times labview needs a good old reboot to start working again. If that doesn't fix it I would try un-installing DSC (from add/remove software) and reinstall it. I've run across a lot of problems with the DSC (as I use it almost daily with my clients) but haven't heard of this one yet.
Let me know how things turn out
Matt
(2,919 Views)
Hi ,matt
 I have fixed the problem, as I found that the reason why I fail to find the I/O server was that the chinese version of labview 8.2 installed has conflicts with the english version of DSC 8.2. After I reinstalled english version of labview 8.2, everything works well!!
from nelly
帖子被nellylee在 11-04-2008 05:27 AM
时编辑过了
帖子被nellylee在 11-04-2008 05:28 AM
时编辑过了
(2,896 Views)
