connect a photodiode
I have a BNC 2120 module and a 6111 acquisition card. I want to
acquire an amplifier photodiode. How can i do this? I have tried to
connect directly the photodiode to the 2120 module, but i can't see
any signal, i think that there is a impedence coupling problem. So i
have make an impedence adaptor, but is this the only way to resolve
this problem? Normally we can see the photodiode with a normal
oscilloscope that have an input impedence of 1 Mohmm. Is there a
special configuration of the BNC module or the card, to acquire
directly the amplified photodiode?
Thank you for the attention
Andrea
(3,045 Views)
Hey Andrea,
Before you worry too much about impedance problems (which are explained here) first make sure that you can read in dc voltages correctly.
Other things to check:
1.) Is the referencing set in MAX equal to the referencing set on the board?
2.) Is the board configured to use the BNC-2120 in MAX?
3.) Will low impedance sources work?
If all of these point towards the source impedance of the photodiode being the problem, then the only real solution is a buffer. Here is a link to information about using a unity gain buffer.
Let us know i
f you have any further questions!
Justin T.
(3,045 Views)
