connect from a sensor to a DAQ
Please help. What else do I need to connect my RGB senser to a DAQ. i just need to see the signal output on my PC. Please help. What type of hardware do I need?
The sensor has 0V and 24V ( sinking and sourcing)Thank you for your time and help.
(2,685 Views)
Hi neil408,
Can you describe the RGB sensor for me? Does it output a specific voltage per wavelength or color? If so, it would be very easy to help you. I'm very confused on what kind of hardware sensor you have. Who manufactures it? What does it output?
Chad AE
Applications Engineer - National Instruments
(2,685 Views)
Hello Mr. Chad:
Thank you for your reply. The sensor is NPN cZ-K1 from Keyence corp( fiberoptic). The output circuit shows: brown 12 to 24V, Black (load) 5 to 40 VDC, blue 0 V.
This sensor detect color change ( 7 different light). My project is just to detect the change of color ( output) so I can save the output to a text file using labview. Please help Mr. Chad. May I ask what hardwares do I need? How do I connect to the DAQ. Thanks again.
(2,685 Views)
