connect lan device
I am trying to control a Hamilton Microlab ML600 syringe pump, which is connected to my pc via an ethernet-to-usb adapter.
The device is working, and the static ip configuration seems ok: I can ping the device, and using the included C# program I can control the pump.
However, the (also included) labview program is unable to connect to the device, even though it was able to do so on a different pc. Also, when I try to add the device via NI MAX, it cannot be found.
Hopefully someone has some idea to help me further.
(2,341 Views)
"Allow LabVIEW through the firewall" would be my first thought.
(2,307 Views)
