connect network-published shared variables to the selector terminal of a case
Hi, I am doing the program for a QA Tester. I'm using network-published shared variables to transfer data, and I have wired one of them to the selector terminal of a case. But when I run the program, labview crashes and quits. If instead I connect a constant to the selector terminal of the case, everything runs normally.
Does someone knows why is this happenning?
Thanks!
(3,071 Views)
Ok I guess it has nothing to do with the variable, because I connected a queue and a shift register to the input of the case, and in both cases labview crashed. But I connected an enum and a constant number, and it worked correctly. So I don't know what's happening =/
(3,064 Views)
showing some code might help...
(3,058 Views)
Here is the complete project, the one crashing labview is main_rio.
Thanks.
(3,055 Views)
Hi Rugebiker, could you post the error message (error code) you are getting? it would be better having an error code to check the possible root causes of failure.
Eric_NI
AE
(3,037 Views)
