connect sql using matlab script
hi i want to connect to sql database and populate coloum values in dropdown menu
for this i am using ring
how to take the coloum values as output
i tried is as string but it throws error
addpath('C:\mym');
myopen('localhost','root','demo');
mym('use first');
menu_list=mym('select * from menu');
Test = unique(menu_list.Test_Type);
i want test as output which has 4 values
pls help me to sort it out
Message 1 of 1
(2,448 Views)
