connect to webservice
did you use something like 127.0.0.1 oder localhost on the server pc where it worked or did you use the public ip address to test?
Message 11 of 29
(939 Views)
Check to browser settings for proxys.
Maybe on both computers only the own ip adress is excluded, so the second test computer browser will try to access via a proxy.
Message 12 of 29
(938 Views)
Have you checked that you specified the Port number (usually 8080 if not explicitely changed) to the URL?
Olivier L. | Certified LabVIEW Developer
Message 13 of 29
(937 Views)
On the server PC both the localhost and the internal IP work well, when I put the external ip on my server PC, I get a "Could not  connect error"
Message 14 of 29
(936 Views)
Olivier:
Yes the port is set to 8080, and I've used in the URL (ip:8080/servicename/viMapping)
Message 15 of 29
(934 Views)
Watchout for nasty proxy settings
Message 16 of 29
(932 Views)
I checked for proxy settings, and no proxy is used for the browsers on both PCs.
I am running out of options
Message 17 of 29
(930 Views)
Double check -> options -> web server -> browser access -> browser acces list = * && "allow viewing and controling" is set
Message 18 of 29
(925 Views)
I double checked, all is in order.
Do I have to configure my router for it to work?
Message 19 of 29
(922 Views)
You said that you entered external IP adress on serverPC, is this normal?
I think your server PC get your webserver.
Then your client PC ask your webserver with the URL, and your webservice answers with datas. Am I wrong?
Message 20 of 29
(921 Views)
