connect with TMSi porti
Can the Labview connect with TMSi Porti?
Does anyone here have try to display the signal from TMSI porti in Labview?
Thanks.
(3,260 Views)
https://www.google.com/search?q=tmsi+port&ie=utf-8&oe=utf-8
google has no idea what you're talking about either.  What port are you looking to work with? What's the communication protocol?  Is there a device in specific?
(3,247 Views)
Actually TMSI porti is a bioamplifier. I want to display EEG signal in Labview from this bioamplifier.
Is it possible to do that in Labview?
(3,236 Views)
The question is wrong. The question is not LabVIEW, but the hardware. You need to check your TMSI product specifications, or contact the company TMSI.
Does this product has Ethernet/USB/RS232/GPIB interface connection? If so, does the company provide any driver to communicate/get data from the device? Other possibility if the device has an analogue output? This analogue output can be connected to an NI hardware (an appropriate DAQ card).
If you can provide us the answer for the above question, we can recommend NI HW and how to use it from LabVIEW.
(3,201 Views)
