connecting Labview to USB in Isochronous mode
hi
its metionned in the the document "Using NI-VISA to Control Your USB Device" that NI-VISA supports only control, bulk and interrupt pipes,
what about Isochronous?
how can i use NI-VISA to ceate a driver for a USB device Using Isochronus pipe?
is there a way to connect LABVIEW to an USB device without using NI-VISA?
the device has the ISP1583 from Philips as a USB controller
your help is much appreciated
Naji
(3,470 Views)
What version of VISA are you using?
(3,456 Views)
im using VISA Version 3.3
(3,446 Views)
Hello Naji,
No Isochronous transfers are not supported.  See this KB for more information about it.
Good luck with your application.
Angela M
(3,420 Views)
