connecting the output of one program to input of another
Hi Everyone, I have a confusion regarding how to connect the output the one program to another input of a program. I am able to run the code for the sick lms 100 laser scanner in the main block diagram. I have achieved distance  and angle using sick lms 100laser scanner. The diagram given below  (position of obstacle) represents the calculation step taken for calucating the position of point B ( AC,BC)= (8.6,5.0001)cm. Now,the major problem comes .
I have other program which is running on the main block diagram. Now, i want to put the output that is point B output which is (AC,BC) = (8.6, 5.001) into the (x,y ) coordinate of this program.Note that: These are two different programs which is not integrated yet. I just want to pass the ouput of (AC,BC) into my program for input (x,y).
can anyone help me?
(4,366 Views)
can anyone help me?
(4,409 Views)
Hello Sapkota,
if you are speaking about VI´s you can use the connection terminal. If both VI should run independent, a easy way is to use a FGV , global variable, notification, queue and so on. If both are programms you need a transfer method like TCP/IP or network variables to transfer values between the two programms.
Be careful because, if you do not know, when the data will be sent or received a race condition can happen. So a little bit more information is need, what programm is mean in your case or a example code.
best regards
Alexander
(4,396 Views)
Both are different program. The first program gives the distance and angle. The second program needs the input of the first program that is it needs x and y coordinate which is measured by first program. It gives the distance (entferungen )here in german language. Now using formula mode in labview by using trigonometry i can calculate the position of B as i mentioned earlier. The main block diagram of output program is given below:
This output should be pass to another program which is input for this program.
(4,378 Views)
Hi Sapkota,
use any of the methods mentioned above!
I would prefer a queue or notifier…
(4,370 Views)
Hello Sapkota,
are the progamm run under Window, because a timed loop is in use.
You are speaking about transferring values between two VI`s then you can use the methods i mention.
best regards
Alexander
(4,369 Views)
