connecting two labview into one
I have created two labviews that runs by itself. The first labview interfaces the movements of a knob. In the second labview, I simulated dynamics of a nuclear power plant into it. I am getting inputs on my frst labview and I want to connect it to second labview where it has a scope for the control rod position. I insterted the image below. Labview1.PNGlabview2.PNG
(4,140 Views)
Hi jay,
for a quick solution you could put all code into one VI and write your measurement values into a local variable to the "Slide"…
Are you sure you simulate "dynamics of a nuclear plant"? It looks so easy…
(4,130 Views)
Yes - a simple solution is to have a local variable from your VISA read and put it in your Simulation loop.
I think you might have to be careful about your simulation parameters - I think you'll need to run the simulation loop in real-time for what you're doing to make any sense?
(blog)
(4,111 Views)
I only simulated for the output I needed not the whole thing.
I am confused on when you siad "slide"
(4,109 Views)
The slide control.  Up near where it says "Control Rod Position".
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(4,069 Views)
Hi jay,
Look at your own pictures! There's a control named "Slide"…
(4,067 Views)
What are "two LabVIEWs"? Are these individually build executables or are both running in the main LabVIEW instance?
(4,060 Views)
