connecting two terminals of different types
Hey,
I am new at this labview stuff, and I am stuck trying to figure this problem out. Are there any converter items or type converter that will help me convert a "type of the source in automation reference class" (activeX) to a "type of the sink is file path"(File I/O).
Message 1 of 13
(4,899 Views)
It would help if you could post your VI that you are having difficulty with. Based on what types you provided doesn't sound like something that will work together. But seeing the code would go a long way in seeing what you are trying to do.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 13
(4,896 Views)
Your automation reference is sourced from a file path to begin with.  Can't you just use that?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 3 of 13
(4,892 Views)
Mark,
here I have attached my VI.
thanks for looking into this.
Message 4 of 13
(4,883 Views)
Yea, that won't work.  If you are just wanting to write to a text file, give it one.  I'm not quite sure what you are trying to accomplish with the range.
Message 5 of 13
(4,875 Views)
As you know I am struggling with the writing data to excel with a specific actions that satisfy my needs. The activeX has everything except for the delimiter, and the labview's "write to spreadsheet file" VI has a working delimiter. So I was trying to incorporate the two together.
Sorry if that sounds abit stupid.
Message 6 of 13
(4,869 Views)
As already stated you can't do what you are trying to do. What specifically do you need from Excel that you can't do with a simple CSV file? You can always read a CSV into Excel and manipulate the data with all that nice spreadsheet stuff once you have the data in the worksheet. I don't think you have to do all the Excel work in LabVIEW.
Mark Yedinak
LabVIEW Champion
Message 7 of 13
(4,867 Views)
So I have a VI that save it into a (.csv) file, but for some odd reason my string doesn't delimits when it sees a comma. can you take a look at this VI and see what went wrong?
Message 8 of 13
(4,832 Views)
Your Array to SpreadSheet String function is removing your delimiter before writing to the file.
Edit: Forget what I said, I was looking at the data wrong.  I'll have another look.
Message 9 of 13
(4,820 Views)
@boodmiester wrote:
 ...but for some odd reason my string doesn't delimits when it sees a comma. can you take a look at this VI and see what went wrong?
What do you mean by this statement?
Message 10 of 13
(4,815 Views)
