connection entre 3 round led boleans
Bonjour, je suis nouvelle utilisatrice de labview et j`ai besoin d`aide pour connecter 3 round led boolean svp,
Je veux trouver un boolean dans la partie code qui permette de controler les 03 led ; lorsque le led 1 est ON, 2 et 3 restent OFF, et iversement pour les led 2 et 3
Hello, I`m a new labview user and I need help to connect 3 round led boolean please,
I want to find a boolean in the code part that allows to control the 03 led; when led 1 is ON, 2 and 3 stay OFF, and iversally for led 2 and 3.
Thank you for your help.
Merci.
(389 Views)
Use a radiobutton control. It is a container for booleans where only one can be true. The type is an enum containing the label of the booleans.
See also this idea.
(373 Views)
