connection lost after compilation
Hi, i am currently using a myrio accelerometer board. I was running my code,  but suddenly, an error pops up telling me my myrio connection is lost. I have checked everything, the usb and the power connection, everything is secured, and this error only came up after i edited my code, so i am thinking if there are anything in my code that causes this error. I have attached the vi and the error snapshot.
(2,779 Views)
sorry, this is a double post thread, can the admin please help to delete this thread? thanks.
(2,777 Views)
You have to use the options button to contact the moderator.
(2,775 Views)
Go into your USB hub settings.  Windows 7 has this silly power saving feature where it will remove power from your USB devices.  You need to disable that.
At least that has been the issues with a lot of USB DAQ boards that run for a long time.
(2,750 Views)
