connection lost after compilation
Hi, i am currently using a myrio accelerometer board. I was running my code,  but suddenly, an error pops up telling me my myrio connection is lost. I have checked everything, the usb and the power connection, everything is secured, and this error only came up after i edited my code, so i am thinking if there are anything in my code that causes this error. I have attached the vi and the error snapshot.
(2,573 Views)
what changes you made when you edited your code. can you save your code which is orignal means without editing
(2,562 Views)
if you mean that after running your vi when stoped in and begin to edit vi , the connection is lost. it is obvious as you run the vi your PC get connected with rio , when you stop your vi  the connection established between your PC and rio is broken ans msg of connection lost pop up.
(2,554 Views)
