connection of Labview with DSO
how to make connection for analog output in DSO from labview
(4,118 Views)
how to connect analog output with DSO?
(4,112 Views)
Hi neha,
when you write "DSO" you talk about a (digital) scope?
- What is an "analog output"? Scopes usually only have inputs!?
- To connect to a scope in/out you usually use BNC cables… (Or maybe more sophisticated connectors for high frequency applications.)
- How to connect a PC to your scope usually is described in the manual of your scope. Did you read it?
To get  more/specific help you should provide more information - especially on manufacturer and type of your scope!
Edit: Please don't create double posts on the very same topic! Keep discussion in one place! (I merged the messages into one thread.)
(4,092 Views)
